box scrapper blade
jennifer408
we need to get a new box scrapper blade for our 76" ? wide gannon box scrapper. i was reading a post not too long ago that mentioned a certain brand that would last forever. i tried looking in the archives and can't find it anywhere. does anyone know about this blade and or where is a good place to buy blades at ?
I assume that you only need a new cutting edge, right? I would first call a Woods Equipment Dealer to see if they can get replacement cutting edges. I had a piece of hardened steel cut for my snow blade at a local steel supplier. I drilled the bolt holes myself on the drill press. I ended up using Grade 8 hex head bolts to hold it on. Mine isn't really a cutting edge, however, so it the edge isn't sharpened.
