I'm not having any luck getting the auger broke loose. its froze solid.
Does the end plates with the 3 bolts per side have a bearing or not ?
im letting it soak every day, I squirt pb or something in the grease plug holes and around the shaft ends.
If all else fails, can I cut the auger into at both ends to remove it, providing it can be welded back once free from the end plates ?
