Just to wrap it up, yesterday I finished the work that needed to be done on the MF31, including replacing the spider in the drive shaft U-joint that I had forgotten was broken. Fortunately, at the time a few years ago, I had bought the replacement part.
The process included replacing the cutter bar with the one from my older NI 30 mower, which I had replaced not many cuttings before it broke and was replaced by the MF31. I guess that"s why we save everything...never can tell when it will be needed!
I had to shorten the bar a few inches and drill a few new holes, and since I didn"t have rivets and couldn"t find them locally, ended up using flathead machine screws for the cutter bar head and sections that were under the strap.
I also used two guards from the old NI30, even though they didn"t fit - when installed, the ledger plate was a little over 1/8" too low, resulting in a big gap to the section. I used what my old boss used to call an Italian milling machine (he wasn"t Italian, but his wife was very Italian), a 4" angle grinder, to grind the seating surface of each of the two guards down by 1/8", and was able to shim the guards to get a reasonable gap.
I wasn"t able to get ledger plates locally, so while I replaced one with one from the old NI30, again using a flathead screw instead of a rivet, the other 21 were the originals with the worn ledger plates.
I was able to "sledge" adjust the gaps on some guards, while others didn"t move much with a whack, so many were shimmed between the back end of the guard and the bottom of the bar.
I tried attaching three pictures: (1) an example of one of the worn ledger plates; (2) three guards showing the vertical distance between the mating surface of the guards and there plane of the ledger plates; and (3) proof of the pudding...a short stretch of my "test drive" showing that even with the terribly worn guards, with the section-to-ledger plate gap set reasonably, the mower is working very well - no jams, and clean cutting. Unfortunately, I don"t think it worked, so for now, no pics...sorry.
Later today I"ll mow the rest of the fields - about 3 acres.
My wife and I are Christians and a lot of prayer went into this. Along the way, there were a number of mistakes on my part, a lot of frustration, and a lot of "coincidences" that resolved problems and mistakes. Y"all know what coincidences are don"t you? That"s when God chooses to remain anonymous!
That probably wraps up this thread for now.
Thanks for your comments.
Optiker/Chuck,WA
