Disc harrow blade questions
Hotflashjr
Location
Western MA
I am looking to replace a few bent blades on my 6 foot drag harrow. I do not know the make. The blades measure 15 inches across with a 1 inch square shaft. It measures at a 2 inch concave. I can't find something like this anywhere. Would I be correct in guessing these were originally 16 inch blades. I only need to replace three blades. If I mix in three 16 inch blades will it affect how the harrow works?
You are correct,16" was the original 'unworn' size.Go ahead and install em.Try to put them toward the center if they are on the front gangs.At 1" 'oversize',that is only 1/2" larger on edge.In normal soft (plowed) ground,you will never tell.....
