Fergienewbee
I'm pleased with my plowing--then I get out the disc and make ocean swells out of it. I get a high ridge in the center of every pass. Disc is a 6' 3-pt hitch. Rear gangs seem to hit the ground first.
Back gangs are set aggressively; fronts look similar.
1. Do I shorten/lengthen the top link?
2. Do I need to adjust the back gangs to cut less aggressively?
3. Adjust the front gangs?
4. Forget discing and plant sod corn?
Larry
Larry
