Plow share numbers Massey 66
I have a manual coming but need to know the part numbers for the shares and shins for a Massey 66 plow that is a 3-16. I see a share available that has four bolts but mine only has 3. Anyone have a book handy?
Thanks.
Jason
The 3 bolt are the older pattern.The ones I've seen are reversable.They will fit either right or left bottoms.Take an old one with you to your supplier as a sample.....
The share will depend on the moldboard that is installed. If it has a 16" general purpose moldboard then the standard share is a 475135M1 but there were 3 other 16" shares offered for that one moldboard. The shin is 660020M91. All together there were 6 different bottoms offered for that plow and each with multiple shares available. If the moldboards are original MF parts there should be a number stamped in the back, as well as the shares should have a number stamped into them also.
