John deere plow model?
I have this set of plows but not real sure what model they are can you help?
Think they will be good match for my 1937 model A
Thanks dan
Looks to be open clutch and both wheels same size so a No. 52. 4 & 4B have larger land wheel. Pulled 2-12" with the 38 A.
Dont know the model number.But it would be perfect for your old 'popper'.Some pics please.BTW,I pull 2x14 behind my '44 A. Perfect 'fit'.
Looks (from here) that the landslides need built-up, and the Hitch is set with a Huge amount of Off-set..
Mine is set for Rear tires set to 29 1/2" from Center to the Inside of the tire tread and yours is set for something even wider-set out..
Ron.
Actually an enclosed clutch #52, the 4B had taller (32") land wheel until 1942 then it was same size as the furrow wheel. Quickest and easiest way to i.d. is to look at beam numbers stamped into the beam after the words JOHN DEERE. #52 has beams 612 and 613 (usually) 4B plow has beams 583 and 623.
