Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Ferguson Cordwood saw part
BMC425
04-12-2014 07:16:59
I have an A-LO-19 cordwood saw that I need to make a part for. The tractor pulley to saw Y shaped brace has been missing since I acquired the saw, and I need dimensions. Could someone supply the hole to hole distance, Please?? The dimensions of the metal strap would also be very much appreciated. The 2nd number of the SN is difficult to read, but appears to be 4, but might be a 1, making the SN 14XXX OR 11XXX. Thanks
Mike
BMC425
04-15-2014 14:14:16
 Re: Ferguson Cordwood saw part in reply to BMC425, 04-12-2014 07:16:59
Thanks for the measurements. I removed the bracket with the lift tabs as one of the tabs was cut off by the previous owner and I need to replace that tab. When I hear back from Ken I can decide the repair.
Mike
Kirk-NJ
04-13-2014 02:00:06
Here is the one off my ferguson saw. It's two piece. The manual show what looks to be a one piece Y. If you want the measurements I will get them for you Will be out plowing today so might not be until tomorrow.
Kirk
BMC425
04-13-2014 06:11:58
 Re: Ferguson Cordwood saw part in reply to Kirk-NJ, 04-13-2014 02:00:06
I would appreciate the measurements. I am talking to Ken now about maybe getting a complete piece, but I see benefits in having another set of numbers. The manual I have shows 2 different Pt No at the 12000 break, mine might be either side of that. Centerline distance, saw to pulley, is what I need.
Thanks
Mike
Kirk-NJ
04-13-2014 17:30:47
 Re: Ferguson Cordwood saw part in reply to BMC425, 04-13-2014 06:11:58
I took the measure from the inside. 13 3/8" from center hole to center hole and 15" over all lenght.
Kirk
Ken Crisman
04-12-2014 16:43:40
Mike, I just got in & heard your message but didn't get the contact info . My machines volumne sucks , so I miss a lot of whats said . If you wanta call me again , I'm home . God bless, Ken
Ken Crisman
04-12-2014 12:14:12
Are you referring to the center link part of your buzz saw ? If so , I made a couple for my two saws (1)Dearborn , & (1) Ferguson . They are the same & I have an extra if interested in buying it .Also does your PTO pulley have that little bracket bolted to it which the center link of the saw clips into so it will lift up for traveling as it supposed too ? I have that part also . My ph # 814 4328034 if you are interested . God bless, Ken
Copyright © 1997-2015 Yesterday's Tractor Co.
