Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Big Bee Groomer
shane12970
04-11-2014 19:46:48
how often do you sharpen the blades? everytime you take it out ... every 4 times any suggestions?
Pooh Bear
04-13-2014 13:01:25
 Re: Big Bee Groomer in reply to shane12970, 04-11-2014 19:46:48
I have a 60" Big Bee finish mower.
I sharpen the blades a couple of times a year during the summer. I do mow little sticks and hit a rock occasionally. I'm not looking to get a golf course looking yard. Just keep the vegetation at bay. I mow every week or so; 3 acres.
Pooh Bear
maxwell99
04-12-2014 04:35:30
If you are cutting nothing but grass then keep it Sharpe, you will just have to check the blade from time to time, all depends on how much you use the tool.
But if you are cutting brush with some small trees, heavy stuff like most of us do then you do not want a Sharpe edge as it will cut the stobs off clean and puncture your tire next time you mow.
A Sharpe pointed stob will puncture a tire like you would not believe.
I bought new rear tires for my TO35 Ferguson this year, the tire dealer said if you are going to do much Bush hogging I would rather have the tires you took off, hate to ruin a new tire.
shane12970
04-12-2014 07:08:03
 Re: Big Bee Groomer in reply to maxwell99, 04-12-2014 04:35:30
ok so if not maintainig golf course every 3 to 6 month..I cut bout 4 acres.. and i never pick up limbs and stuff....lol. Thanks
maxwell99
04-12-2014 07:26:44
 Re: Big Bee Groomer in reply to shane12970, 04-12-2014 07:08:03
this is a picture of my little hog.
5 ft model
main thing to check each use is the bolts and nuts holding the blades onto the stump jumper and that the big nut holding the stump jumper to the gear box had the proper cotter key and nut still in good order.
my friend was hogging I the woods and one of his blades came off, loud noise and it when about 20ft out and hit a tree. good thing it did not get him or the rear tractor tire.
be careful, a rotary cutter and a chain saw are about the two most dangerous things a good old boy can use around the farm.
shane12970
04-12-2014 12:20:14
 Re: Big Bee Groomer in reply to maxwell99, 04-12-2014 07:26:44
Mine is a finish mower... I dont cut anyting higher that about 4 inches... Just the yard i would normally use riding mower on
Copyright © 1997-2015 Yesterday's Tractor Co.
