TractorLinks.com
Re: Disk ID?
Tom-NoCenTX
03-20-2014 05:46:02
It is a John Deere. Got a green one just like it.
It is JD Model WH, with the original model probably something like WH-075, meaning 75 inches, 10 disks wide cutting 7 1/2 inches each.
JD literature is termed as follows:
Harrow, Disk, Wheel-Type, Offset -- Model WH
Tom
Tx Jim
03-20-2014 06:08:20
 Re: Disk ID? in reply to Tom-NoCenTX, 03-20-2014 05:46:02
Tom
I don't see a model WH-075 in the parts catalog
Rich.Fl
03-20-2014 15:01:55
 Re: Disk ID? in reply to Tx Jim, 03-20-2014 06:08:20
Tom n' Jim-
Thanks again for the help! I've been putting a fair amount of work in it, to get it right. Now that I know the make and model perhaps I can find some parts if needed (wheel bearings need to be re-
worked at least.) Today I was a little more enthusiastic...working a little harder to get that rust cleaned up :)
Rich
Tom-NoCenTX
03-20-2014 14:31:34
The Model WH76, means Wheeled Harrow 7 ft 6 in, which is 90 inches of cut or 9 inches per disk. My mind still works but like an old tractor - - a little slow. Tomk
Tom-NoCenTX
03-20-2014 14:27:03
Can't you give an old man a break? I have a Model WH76, which stands for 7 feet 6 inches. I was just trying to quickly help the fellow out, without going out to the offset and reading the tag. Regards. Tom
Tx Jim
03-20-2014 16:13:41
 Re: Disk ID? in reply to Tom-NoCenTX, 03-20-2014 14:27:03
Tom
I was just posting correct information not trying to pick on you. BTW I'm fairly long in tooth(69) and make mistakes and have been corrected for my mistakes several times. If I make a mistake I want someone to correct me.
Regards,Jim
Rich.Fl
03-20-2014 06:02:33
Thanks Tom!
That is really helpful. A lot of knowledgeable/smart people on these forums:)
Rich
