BLUE-SPRED lime/fertilizer spreader
Ziggy1979
New User
Looking for some documentation on this spreader we picked up at auction, but can find absolutely zero on the internet.
Sticker on the hopper says "BLUE-SPRED series C-5020 or C-5035"
A manual would be ideal, but even some basic operating instructions would be better than nothing. Thanks a bunch.
I did not find any information on your spreader.
You might just run your own test: add a set weight of fertilizer to the spreader, set your pto rpm and forward speed.
Run machine until bend is empty: measure width and length of ground covered.
I realize this method is very red neck, but at this point, unless you can find a similar scale this may be the best you can do. Run two or three test at different settings.
I do not understand why there is no data on this spreader?????
There is a chart listed on the spreader, regarding PTO speed and such. I really just wanted some basic instructions as I have not used one before.
I heard that I have to be careful not to forget to turn a lever or open a hatch of some sort before filling it, or I'll have to shovel it out by hand.
Thanks for the response
