TractorLinks.com
Re: 2bottom dearborn on a JD 70??
Leroy
03-18-2014 03:18:34
You could never get that Dearborn to work on your tractor as they were made for a 52" tire wheel track and your 70 if it will narrow down to what an A would will be 56" and then you would be close to rollover spacing. Tractors of that height we never set the tread width to less than 66", that is center to center of rear tire. Always had drag type plows on them tho. And sweeps on a chisel plow, that would not work around me, you could only pull perhaps 3 sweeps here if you could even get them in the ground. I say get the 4" twisted shovel for your chisel and here with your power you could only pull 5 shovels. And then only 5" deep in the alfalfa.
dmiller
03-18-2014 06:39:38
 Re: 2bottom dearborn on a JD 70?? in reply to Leroy, 03-18-2014 03:18:34
I use the chisel plow on a Wheatland 806. The 70 has the three point so that's why I mentioned it.
