TractorLinks.com
Re: 2bottom dearborn on a JD 70??
DeltaRed
03-17-2014 20:54:47
Use the chisel.Go over about 3 times in alternateing directions.If you can,try to go a bit deeper each time.IIRC,you're in flood irrigated country.You should try to bury the 'trash' for better water flow.I'm sure someone close will plow it for you.Just ask.It may cost a couple hundred....Then you can do the rest.As was said the 70(it has MORE than enough ponies), lacking draft/depth control will be tough(a challenge) to use on a mounted plow.But you can use a chain to hold the plow to a constant depth.I've had to do that sort of thing when I've pulled a 3 bottom rollover with my Super M.Worked great!Plowed level and even while supported.
dmiller
03-18-2014 06:44:29
 Re: 2bottom dearborn on a JD 70?? in reply to DeltaRed, 03-17-2014 20:54:47
I think that's what I'll do. Time is always an issue for me. The Chisel/806 will do the field in about 1 1/2 hours, will not hurt or use much more fuel to do the field twice. It will get disced once to bury trash and smooth it up before planting, last pass I pull an old spike tooth harrow behind the disc.
Thanks for the advice.
BushogPapa
03-18-2014 05:49:02
That has always been the problem with the Models prior to the "20 Series", they needed a Depth Wheel (gauge Wheel) to control plowing depth.
A decent "Pull-Type" plow would work fine too. Only thing about using one is getting used to larger End-Lands because of the added length..and backing it when plowing off the ends..
I assume you will not need to have a Dead Furrow, with only 5 acres, just turn it all toward the middle, to keep the field level..
Ron.
