Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: IH 22 sickle mower parts
TIMnMD
02-21-2014 20:02:40
Thanks to everyone for all your help. I will post a picture of the mounting arms I have tomorrow and hopefully someone will know if either one is factory or even correct, one is broke and the other is a patched up welded mess. Another question: I plan on taking the mower bar apart to clean as it has some rust. Should I lube the cutter bar and if so with what product.
Thanks again,
Tim
C. Amick
02-22-2014 19:11:51
 Re: IH 22 sickle mower parts in reply to TIMnMD, 02-21-2014 20:02:40
Pull the knife out and sharpen each section with an angle grinder (wear gloves). Check to make sure all the sections are tight. Shake each of the guards on the cutter bar and make sure they are tight. You can oil the knife a little with some motor oil before you slide it back in. Once you get the knife back in you can put some grease on the tip side of the knife where the hold downs rub it. Grease and oil won't stay on the cutter bar anyway, once you start using it.
