Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
gm or others power steering pump
36 A
02-16-2014 10:45:29
who much will a power steering pump from a car or pickup lift ? will they lift a two bottom plow and last a fair amount of time ? I"ve seen people use them on other things a thought it would be an easy way to put one on an old tractor . a friend has one on a shop press . anybody tried one for this ?
farmeroz
02-17-2014 11:26:24
 Re: gm or others power steering pump in reply to 36 A, 02-16-2014 10:45:29
Find a power steering pump from a GM truck with the hydraulic braking system. Those pumps have three lines connected to them and they are a bit heavier and a slightly larger resivor.
mmidlam
02-16-2014 14:13:31
I saw a 1 ton dump truck where the hydraulics was powered by the power steering pump. The pump was fed by a large hose connected between the fill spout and an external 15 gallon reservoir.
Paul Janke
02-16-2014 13:42:17
Most power steering pumps have built in pressure relief and priority flow valves. They won't put out more flow at higher speeds. I have dismantled pumps and eliminated those features for higher flow rates and higher pressures. It was worth it for me under the circumstances.
Bob
02-16-2014 11:51:43
A typical full-sized one is rated at 850 PSI and about 3 GP.
NOT a lot for running tractor hydraulics.
For example, a typical loader pump on an old 8N Ford can be 12 GPM at 2100 PSI.
old
02-16-2014 11:51:13
A GM power steering pump off one of there bigger trucks puts out in excess of 1500PSI so with the right cylinder it will lift a heck of a lot. I built a sickle bar mower out of 3 junk ones and belly mounted it on a Farmall B and used a small hyd cylinder to lift it and it worked just fine
DeltaRed
02-16-2014 10:56:42
A neighbor has a PS pump on an AC 'WC'.It runs a loader and a 'sorta' 2point.Seems to be quite adequet for the job.
36 A
02-16-2014 19:11:08
 Re: gm or others power steering pump in reply to DeltaRed, 02-16-2014 10:56:42
thanks that's what I needed to here I might try it . not gonna be out much if it don't work
old
02-16-2014 19:31:02
 Re: gm or others power steering pump in reply to 36 A, 02-16-2014 19:11:08
Biggest problem is the lack of a tank of much size so using a larger cylinder 2 way helps slave that problem or rigging another tank to it
504
02-17-2014 19:01:51
 Re: gm or others power steering pump in reply to old, 02-16-2014 19:31:02
Article in Mother Earth News back in the 70s had a PU running a hoist from the P/S pump.
