Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD Trip Plow Conversion
NY 986
02-16-2014 05:12:42
I never heard of anything like that being done. The engineering of the plow would not be too hard but there will be expense making brackets and obtaining cylinders. Some manufacturers back in the day had a system for using the tractor hydraulics doing the reset but that was with systems that developed in excess of 2000 pounds pressure neither of which the H or B will do. Then it comes down to upgrading the hydraulics or using an accumulator system that uses special gas (nitrogen) for the push back element. More expense plus finding somebody that can recharge the system periodically. The bottom line for me would be it is too expensive for the return seen and if it were me I would live with it. Probably something that would at least bypass the hydraulic issue would be to graft a spring reset assembly onto a plow. It will take a lot of research to figure out and a shortcut might be to find a mounted plow such as an Oliver that already has it and put a three point system on one of your tractors. Again, I hope it would be worth all the fuss. If there is no reason to press the B or H into doing this plowing then I would bypass the whole project finding a three point hitch tractor then find a suitable mounted spring reset plow.
NY 986
02-16-2014 05:46:53
 Re: JD Trip Plow Conversion in reply to NY 986, 02-16-2014 05:12:42
For some reason I thought you wanted to make the plow an auto-reset. Were you simply wanting to go from mechanical lift to hydraulic lift? If you just want to go to hydraulic lift I would check with a parts yard such as Fry's in Pennsylvania as they could ship you the parts if your plow is a model 44 or something similar. Fry's 570-546-3968.
Copyright © 1997-2015 Yesterday's Tractor Co.
