International 80 snowblower value?
I just ended up with an international 80 snowblower it only has lower auger but it seems to operate just fine I just tried it out but I would rather plow my driveway so just wondering what is a reasonable price to ask located in vermont
Thanks dan
How wide is it? I bought a McKee snowlander, 8' model (has two augers) and it had (when I got it) a manual chute. I put hydraulics on the chute both top deflector and to rotate the chute. Anyways, I think I gave $1100.00 for mine in working order, and it had manual controls.
If you have deep snow, or a long open driveway....the blower is lightyears ahead...
$1000 would buy one "here" with hyd chute. Seen them both single and double auger.
I've seen them go for $800-$1500 on auctions and listed on CL from $1000 up to over $2000.
Casey in SD
I thought if they only had one auger that they were called a model 70 then? Or can you see where the 2nd auger was there and now is actually missing?
70 is slightly narrower and only one auger.
80 had second auger optional.
The "scoop" is shaped different on an 80 than a 70 to accomodate the 2nd auger.
Same gear box 70 & 80, but 80 had cross member on top and bottom of gear box, 70 just mounted on bottom.
