ALLIS CHALMERS PLANTER
Kinda depends on your area and demand.Here in West Colorado,50 bucks at best.'Back east' in garden/food plot areas,300 and up.
Depends on which planter, and if the 3 point is cobbled up, or factory. Post a picture, and you'll get more response.
here is a picture of one that was made from a larger planter,
each planter unit was attached to a tool bar.
3pt hitch welded up and attached to the planter.
Note to the wise: one concern is, can you still buy planter plates for this machine. That is the main problem with these older planters. If you can not get planter plates for the seeds you want to plant, you have nothing but scrap iron.
just check it out before you buy!!!!!!!!!!!
I have an old john deere planter with 25B units attached to a tool bar,
same type of planter, but john deere still had the parts I needed to get in back in full service.
good luck with your planter,
small planters are high dollar and getting harder to find. almost every year I get my planter out to plant my gardens, someone will stop by and ask if its for sale.
its hard to plant a garden spot with a 16 row planter
An amazing coincidence is that AC and JD old style plates are interchangeable, and newer ones just need a center adapter...
