JD Bailer Fly Wheel Shear Bolt Bushing
That is the easy way to repair, I had mine welded and re drilled, harder steel. Broke a couple last year just of to much fed it. You also want to repair the drive arm also so the holes are tight and not sloppy. The are was over 200.00 at Deere.
Replaced one in our 336 last year. Drove it out with a hammer and punch. I supported the flywheel from behind to minimize the stress on the cast of the flywheel. As Tony W mentioned I also resized the hole in the arm at the same time to remove as much play as possible.
