John Deere One-way drill (pic)
David from Kansas
Have never seen one of these but have heard about them. This one is located in southwest Kansas where they may have been more common.
I've always wanted one of those, where in Kansas is it located? As a kid I cut my teeth pulling a oneway, we ran the grain drill at the same time right behind it. It sure would save some time that away.
I'm not sure, but I don't think a seeding att. was made for 1400 or 2400 disk tiller; Thinking pic is a 1900 seeding tiller ; PC-1466 .. It would be newer, made into early "70's...
Case made them as well this is mine, I got it out of Canada they sold very well in certain areas there this one is late sixtys build, they were made from the 40's -1970 or so by Case
I assume that is just transport position to make them fit on the road, and they pivot out to a normal drill somehow for planting?
Paul
they do run narrower for trans port but they do not run full width when in work mode, they run at a angle like a offset disc gang runs like in the pic above
Thanks guys.
Too far away from the wheat areas here to ever see anything like that.
Paul
This type outfit was popular in Canada, I have only seen 2 in NW KS, I would think that it would still be usable for dryland farming.
