TractorLinks.com
Re: Conditioning Rolls
Brendon-KS
12-30-2013 17:16:10
When I have observed Circle C rolls vs. factory rolls in otherwise identical headers running in the field it always appears that the capacity is reduced considerably due to poor feeding. The rolls just aren't as aggressive as intermeshing rolls. There have been many iterations of groove patterns over the years in an attempt to solve this issue. My experience is from quite a while back so maybe this has been improved with later designs. A number of the operators we interact with used to have one or two of their machines set up with them but now it seems you just don't see them around anymore, at least in the areas we work in. The factory-made conditioner designs have improved over the years and as a result the benefits of aftermarket systems has decreased, especially when warranty and resale value is factored in.
This is just my experience from field observations and talking to windrower owners and operators so take it for what it's worth.
Hay maker2
12-31-2013 05:17:17
 Re: Conditioning Rolls in reply to Brendon-KS, 12-30-2013 17:16:10
Thnaks, I guess do they crush the hay good? Does the hay dry down better is what my main question is. I will be using these in a JD 1209 haybine and I usually run between 4 - 5 mph. I don't want to think that i will have a feeding problem at these speeds, but I do not know for sure??????
Elton Fancher
01-01-2014 14:34:42
 Re: Conditioning Rolls in reply to Hay maker2, 12-31-2013 05:17:17
I have a 1209 and a 1219 junked. Both have pretty good rollers. Would be cheap. May go to scrap soon.
hay maker 2
01-02-2014 05:49:15
 Re: Conditioning Rolls in reply to Elton Fancher, 01-01-2014 14:34:42
Like wise, where are you located at?
Elton Fancher
01-05-2014 03:07:14
 Re: Conditioning Rolls in reply to hay maker 2, 01-02-2014 05:49:15
I am in central Ky. near Glasgow.
NY 986
01-02-2014 05:27:49
Where are they at?
Elton Fancher
01-06-2014 15:30:31
 Re: Conditioning Rolls in reply to NY 986, 01-02-2014 05:27:49
Phone is 270-670-4918 if you are close.
