Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Dump trailer buying advice.
david1
12-30-2013 14:56:21
67.233.92.233
looking into getting a dump trailer. looking for advice on good brands, also if seems they come in several different weights or specs like lightweight, medium and heavyweight . I live about 2 miles from a quarry and want to be able to get rockdust and gravel. As well as haul mulch, firewood hay etc. Will the electric lifts dump 2 tons of gravel. Thanks for any advice.
[Reply]   [No Email]
RoyB
01-03-2014 14:50:21
23.29.217.125
 Re: Dump trailer buying advice. in reply to david1, 12-30-2013 14:56:21
Hi David
I would look hard at the Big Tex. I own a 20K H&H, and would never recommend another.
[Reply]  [No Email]
Dean Olson
01-03-2014 07:56:11
166.147.72.48
I have a 8'x16' 25k big tex dump trailer. It works perfect. I can theoretically load 17 k. That is no where near "full" as far as volume goes. That works out to about 5-6 yards of crushed concrete. It just barely dumped. Hydraulics aren't up to that weight. I now haul about 10-12 k and it works perfect.
Battery would last only 3-4 dumps with small charging wire. I ended up running #2 wires from the battery on the truck to make it last all day and as fast as I can make a run.
Pay attention to dump agle. 45 degree is about right. Anything less and sticky material won't dump. Scissor lift only. Dual cylinders seem to be problematic.
Back into your GCWR of you vehicle and get the biggest volume trailer you van afford.
Gooseneck is far easier to handle than the smaller bumper pull I used before.
Shop for a servicing dealer. That's going to be more important than the brand.
[Reply]  [No Email]
glennster
12-31-2013 13:20:54
99.90.9.201
i bought a doolittle last spring. 14k gvw, 14 ft long. get one with a scissor lift, not twin cylinders. if loaded crooked, you will bend a cylinder. mine came with the tarp, 3 way tailgate, onboard 120v battery charger, and a wireless remote and a corded remote dump controls. also has skid loader ramps stored under the rear. mine is also wired to charge off the trucks elecrical system. anout 7500 out the door. heres a couple pics
[Reply]  [No Email]
glennster
12-31-2013 14:49:51
99.90.9.201
 Re: Dump trailer buying advice. in reply to glennster, 12-31-2013 13:20:54
here is a link to their website
[Reply]  [No Email]
Tom Schnitzler
12-31-2013 05:30:01
166.182.3.212
Hey, my dad and I made a dump trailer from an old feed mill frame, just get a hoist from a barge wagon and build a bed we made an 8by8 bed then put on 18 inch sides. It makes a handy trailer for wood, gravel and fill dirt.
[Reply]  [No Email]
12251hd
12-31-2013 05:02:43
76.111.85.64
I have a 6x10 Homsteader that can easily haul and dump 2.5 tons of gravel. I opted for an over-the-axle bed, which provides greater ease in dumping brush, etc. With tailgate flat, I can also put 3 round bales in it and haul/dump them--they slide out. I found this used one at a trailer dealer.
[Reply]  [No Email]
dennis min,
12-31-2013 06:37:35
71.55.128.232
 Re: Dump trailer buying advice. in reply to 12251hd, 12-31-2013 05:02:43
12251,
Your comment about the over-the-axle is valid. Some dump trailers will not raise high enough because the tail hits the ground too soon.
I've seen it firsthand, especially when on uneven terrain.
D.
[Reply]  [No Email]
thurlow
12-30-2013 18:21:53
74.177.47.212
We had a Howle way back when; had a 400 bu (24,000#) capacity grain bed on it; 12v-driven hydraulic hoist worked great.
[Reply]  [No Email]
Handyman
12-30-2013 15:43:46
74.85.206.2
I have a 6x12 Bri-Mar trailer with a 10K max load capacity, after subtracting the weight of the trailer it leaves me with about 7200 lbs actuall capacity. it will lift 2 tons but they are not fast, but it beats shoveling by hand. get the biggest bed you can afford but don't plan on filling it full of heavy loads like gravel and dirt or you will be shoveling some off till you can get it to lift. a large bed will allow you to haul light bulky stuff like tree limbs and compost easily.
once you get one you will wonder just how you got by without one all these years.
[Reply]  [No Email]
rick n ohio
12-31-2013 06:17:20
70.208.197.228
 Re: Dump trailer buying advice. in reply to Handyman, 12-30-2013 15:43:46
i have a 7x14 dump trailor 14000 lb axels ,the stone quarry is twenty minuets away,i try to keep it around 4 1/2 ton net weight on it .(depends on the mood the loader operator is in)mine is power up power down 12 volt system,but after about 4 loads the battery is pretty much shot.
RICK
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
