I am trying to remove/repair the tongue on a NH492 haybine and cannot get the PTO shaft out. I have drilled out the set screws on the front bearing lock collar and it will not move.
What holds the PTO shaft in the yoke at the slip clutch end? I have wire brushed, inspected and cannot see anything holding it. I have looked at the parts drawing and it does not show anything holding the shaft to the yoke?Thank you
