vegetable plates for JD 7000 plate planters
I build 2 row plot planters from larger jd 7000 planters. I have customers that would like to plant more than just corn milo and soybeans. Does anyone make plates for vegetables? If so do I need different hopper bottoms also? And does anyone have these?
JD 7000 mostly came with finger pickup for corn, the spilling cups for beans setup around here.
In some areas the plate style was still popular, and the 7000 came with a plate design in those was.
Which type are you getting, exactly?
It is one or the other, you can't fit a plate into a finger pickup, you need the whole mechanism.
Paul
JD made a 'vegatable' planter that used 'plates'(dont remember the number).Totally different than the finger pickup style.You might try the 'Planet Jr.' type planter.That was a yery good planter for veggies or just about anything.As was said the finger pickup style and plate type are totally different and are not interchangeable.
Here in central Kansas the plate style of Deere 7000 is about all you find because when these planters were new there was hardly any corn or soybeans grown here. Milo was the major row crop and for that the plate version is more accurate than the feedcup. These planters use the standard Deere plates, the same ones as the 71 unit planter. There is a wide variety of plates available including many for planting vegetables such as sweet corn, green beans, melons, onions, etc. As the others have said, the finger pickup version of the 7000 is basically a corn and soybean specialist.
Yes I am referring to the plate. We were once in milo country also. Only plates I can seem to find is corn milo and soybeans. Do you have a source for the others?
If this is a plate type 7000 (very rare here, don't even think of them, I've only seen one in my life!) I would think Lincoln Ag would have everything you need, including blanks to drill your own:
http://www.lincolnagproducts.com/
Paul
Planter plates
Many are actually still available from Deere; I ordered a pumpkin plate from the dealership a few years ago. Plan on around $30 per plate if I'm remembering right. I've also picked up quite a few for a buck each at used equipment yards in areas where vegetables are/were grown. Note that for many of the vegetable plates the correct filler must also be used.
I have a pdf copy of the PC0268 seed plate catalog from 1981 that lists everything they made. Shoot me an email at nafziger (at) mtelco (dot) net and I will send you a copy. This catalog also spells out what filler plates or hopper bottoms are required.
I have 6 of the plate units from a 7000 I changed over . They can be bought cheap if ya want them .
I'm in North Central Ohio
They are somewhat common around here. Lincoln Ag only has corn milo soybeans and sunflower. I have talked to them. Thanks for the reply.
