TractorLinks.com
Re: jd 8 ft pull type disc
Bo in mo.
12-17-2013 09:37:55
BTDT! Soak axle nut with wd-40 for a couple days, drop disc in the ground, loosin up with big socket and cheater pipe.If the blades want to still spin, use a big pipe wrench on axle to help keep from turning. If it doesn't come loose then, apply some heat to nut and shaft, if that doesn't work cut nut off with torch. Good idea like someone else said, cut washers from old blades if needed.
rankrank1
12-17-2013 20:40:40
 Re: jd 8 ft pull type disc in reply to Bo in mo., 12-17-2013 09:37:55
Even though dad had a big 3/4" drive socket set back in the day it seemed we often had to use a pipe wrench on the axle nut as well. Only thing we had that would fit some of those very large axle nuts.
