TractorLinks.com
Re: jd 8 ft pull type disc
rankrank1
12-16-2013 19:05:11
yep pretty much as simple as it looks.
I recommend you keep your old blades in case you need to cut the center out of them to make you some custom washers.
Often the axles stretch, the spools can wear a bit in length if run loose, sometimes there are just bad threads on the axle in spots, or new blades not being as thick as the old blades. Any of these issues can often be remedied with some washers cut from old disc blades so everything tightens up.
Tx Jim
12-17-2013 04:09:06
 Re: jd 8 ft pull type disc in reply to rankrank1, 12-16-2013 19:05:11
I think you'll find it easier to remove disks & shaft from machine if the disks that require replacement are very far inside the nut end of shaft.
