Anonymous-0
What is the easiest plow to pull and you can still get parts for? Possibly looking at semi mounted or pull type hyd lift. Possibly 4 or 5 bottom.
(quoted from post at 22:19:42 11/17/13) It"s funny to read all of the "testimonials".. What farmer has ever put a tension gauge on a plow to determine...."ease of pull"???. It"s just a personal non-measured, opinion! Can vary year to year, moisture, soil conditions, bragging rights. Or, more importantly, compared one or another, in a real, measured pull? I"m betting- NO ONE! In 41 years I"ve just gone by what worked, as technology changed over the years. My first 4-16 Melroe in 1973 was a big improvement over an AC 3-16 trip that didn"t work......all the way up to the 720, 548, 588, til I went to the 435 Disc chisel.....and don"t plow anymore!
(quoted from post at 14:36:23 11/18/13) 2 Old,
"What is the easiest plow to pull and you can still get parts for? Possibly looking at semi mounted or pull type hyd lift. Possibly 4 or 5 bottom."
That was the question! I'll still say Kverneland! Now, if you want to talk cost, that's a whole different ball game!
Dave
(quoted from post at 11:42:54 11/18/13) The plow that will pull the easiest is the one that is properly hitched and adjusted. I see so many people plowing at plow days that have absolutely no clue how to set a plow or to run it after it is set. Plowing and setting a plow are becoming lost arts. A very minor adjustment in a plow can have a major effect on how it pulls. You don't just hook to a plow and go. There are several critical adjustments to be made to make them perform like they should, regardless of brand. How a plow is scoured has a major effect on how hard a plow pulls as well. I have pulled a 5-16" John Deere 145 plow with a 4020 and pulled right with a 1456 IH with an IH 5-16" plow at the same depth up hills and down and had no trouble keeping up. It's all in how they are set. Mike
