TractorLinks.com
Re: Heating a JD needle to straighten
Dick2
11-12-2013 00:19:56
The needles on our 14T were made of maleable iron, designed to be straightened cold in a press. That was their primary means to adjust the needles for the required clearances.
We used a new needle for a pattern and straightened used needles to follow the same contour - no need to heat them.
Tx Jim
11-12-2013 03:38:44
 Re: Heating a JD needle to straighten in reply to Dick2, 11-12-2013 00:19:56
Dick2 said: (quoted from post at 03:19:56 11/12/13) designed to be straightened cold in a press. That was their primary means to adjust the needles for the required clearances.
Dick2
When ever I repair a sq baler that has needle adjustment problems I use the 2 bots and slots in needle frame to change needle to knotter relationship. I've never read in baler manual where it stated bend needles to align with knotters.
This post was edited by Tx Jim at 03:40:28 11/12/13.
Dick2
11-12-2013 05:29:55
 Re: Heating a JD needle to straighten in reply to Tx Jim, 11-12-2013 03:38:44
The slots provided where the needles bolted could only accomplish certain adjustments.
My Dad was an old binder man so he recognized that the needles were made with maleable iron the same as on the old binders. Bending the needles accomplished the job of "fine tuning" where the needles had to travel to get the twine to the right place on the knotters (which are also basically the same as on a binder).
Tx Jim
11-12-2013 06:40:57
 Re: Heating a JD needle to straighten in reply to Dick2, 11-12-2013 05:29:55
If needles can't be adjusted correctly without bending then the needle frame is bent.
