Yesterday's Tractor Co.
Shop Now View Cart
Re: Bill hook will not release knot after making it.
longmeadow farm
11-11-2013 09:24:07
9 times out of 10 it is the wiper arm. they get a little worn or bent and don't clean the twine off the hook. If you haven'r adjusted the bill hook spring I would suggest checking the wiper. To test I always loosened the knotter frame and rotated the frame upward checking the wiper clearance. It should drag ever so slightly across the bottom of the bill hook. Check your should give you the "clearance". I've always had JD square switched to big round.. but that is what I did in the shop every winter.
