TractorLinks.com
Re: JD 7000 planter vs 7200 planter
Mike Aylward
11-06-2013 11:06:10
I have a Precision Planting machine and I can assure you that factory Kinze meters are miserable at metering seed. The finger carrier on a Kinze is very flexible and will NOT meter as well as a John Deere or PP meter. A Precision meter will let you meter a wider range of seed sizes more accurately but they do require more user attention to do so. They are not a "pour and go" meter. A John Deere finger carrier is much more rigid than the Kinze counterpart. The PP finger carrier is very similar to a Deere except the individual fingers are numbered and the "flags" are shorter than the original Deere style. Deere went to this shorter flag carrier many years ago. If I were to build the perfect meter I would use a Deere finger carrier and a PP back plate with the adjustable brush. The curved seed belt PP offers is ok as well but is not as much an improvement as the back plate is. A Skip Stop metal cover is a good improvement as well.
Original 7000 covers were made of a different kind of plastic that got extremely brittle over time. Deere subbed this part many times and finally found a compound that is much tougher. These newer covers will all fit on a 7000. Another thing that makes the covers break is drive misalignment. Each metering unit and box should go on the same row each and every year. They should be checked periodically for alignment, especially if one is no-tilling in hard or tough conditions. Mike
LA in WI
11-06-2013 21:23:50
 Re: JD 7000 planter vs 7200 planter in reply to Mike Aylward, 11-06-2013 11:06:10
Mike, I am on my 3rd Precision Planting machine thru 15 years and have installed thousands of PP components. I also have many new prospects bringing in KZ or JD meters for inspection/calibration. In spite of those thinner carriers, the KZ fingers, if in good condition, will produce fewer skips with flats than JD. With round seed, the JD do fine and the KZ will sometimes produce a few multiples. As skips are the most costly in a field I do not install any JD parts in any meter.
The thinner KZ finger carriers do well until the finger wear dictates replacing with PP sets. That "scare story" about those KZ carriers is mostly negative hype.
Yes, the PP components are the best performing.
Yes, the PP composite back plate with the adjustable brush is the way to go. With fingers showing wear in any meter, I always replace with a PP finger set.
However, I do not push new PP parts on a customer until the situation warrants (running the meters on the machine is the real test). If new parts are warranted, I always check with the customer first and, after I give him the options, I let him decide how he wants to spend his money.
LA in WI
Check the skip stops for cracking every chance you get. "Nuf said.
Mike Aylward
11-07-2013 05:50:26
 Re: JD 7000 planter vs 7200 planter in reply to LA in WI, 11-06-2013 21:23:50
In my experience the thin Kinze carriers are not "hype". I am not a Precision dealer and do not care if I install them or not. I recently did two different Kinze planters with one being only three crop years old. They complained it never really did the job they expected it to do. Every row in the planter was not up to expectations regardless of seed size or type. I usually run at least three different seed sizes on each test. All components had been replaced EXCEPT the carriers as they appeared to be ok. I had a used John Deere carrier on hand from my previous planter (7000) and installed it just to see what happened. It worked much better. We went ahead and installed PP parts, including the carrier, and it would consistently plant in excess of 98.5-99%. It would only do about 91% as delivered. While I have not done this for as many years as you have I HAVE rebuilt finger meters for nearly 30 years. Every Kinze/Shoup carrier that I have checked has acted EXACTLY like this. Mike
