TractorLinks.com
Re: drag type disk
moday
11-04-2013 15:37:21
Does it make sense that the front bumpers would bump on the first row but the second row is a foot apart. I need to figure out how to upload pictures. It works great on it's weight alone. Not easy to transport so I'm sure that is why it was left here. There are some springs on top joinging left to right in back but not the front. I need to replace a couple disks too. I've considered buying a 3 point disk but this works fine for what little use it gets. thanks in advance, moday
moday
11-05-2013 16:33:16
 Re: drag type disk in reply to moday, 11-04-2013 15:37:21
I will work on pics when I get home one earlier evening. Too dark right now after turning clocks back. Thanks and pics to come. I'll also try to look all around for a brand.
El Toro
11-05-2013 07:54:55
You need your pictures downloaded to My Documents or Pictures. When using the Advanced Posting Tools on any of the forums when you click on "Browse" it will take you to either one. Here's a few instructions for posting pictures.
If the print is too small to read hold down the "Ctrl key" and tap the Plus + key. Hal
Leroy
11-04-2013 18:27:08
Front row the blades are concave to the outside and so the bumpers, the second row the blades are concave to the inside to return the dirt to where it was before the front row threw it out so it is made to have that foot of space in between the back rows, if it didn't it would be pluging there.
B-maniac
11-04-2013 16:13:12
Here are two JD models. The first is a JBA but they don't have springs as you said yours did. The second is a later model KBA which does have the springs front and rear. May or may not be one of these but these are the only pics I have.
Edd in KY
11-06-2013 19:17:00
 Re: drag type disk in reply to B-maniac, 11-04-2013 16:13:12
Thanks for the photos, now I know that I have an old JBA. Believe it or not, I like to use the front half, set almost straight ahead to cut grooves in the pastures in early spring before I broadcast grass and clover seed. I know that is not the proper usage ...but it works. I get very high germination rates....and it is easy to hook up and go.
