Bottom plow for Farmall 350
Rick Zayatz
New User
I'm looking for the fast hitch bottom plow that was sold for the 1958 Farmall 350 row crop tractor. Any ideas what model plow I should be looking for? I have adapter lugs that the previous owner included that would adapt the 2 point fast hitch on the tractor to a 3 point so I'm pretty sure any 3 point 2 bottom 14" plow would work with this tractor, I'm just looking for the plow that was designed to be pulled.
Thanks for any help.
Rick
One big factor is where you are. I have a 2 bottom disk plow that is a IH fast hitch type and hangs on a 300U we have and other then some surface rust works just fine but I am in Missouri but my e-mail is open
My neighbor has a fully Restored 350 he is looking for a 2-Point "FastHitch plow for it ( in Ohio)..
Is the 350 considered a 3-Plow tractor in average soils..?
Thanks..
Ron.
I have a 3-bottom (three 14s) Int Fast Hitch model 311 that I used for years behind a 1958 Farmall 460 here in south-west Pa. It's a big heavy plow with the box frame. In some of our limestone clay, it was second gear low side or direct first. 460 probably 10 more hp than 350, so 3-14s would work the 350 in some soils.
It all depends on where you are at.And what type of soil.2 bottom,3 bottom,one way,rollover.....It would probably be a fast hitch,or even a pull behind.But definitly NOT a 3 point.There was no 'specific' plow for a 350.Or any other tractor for that matter.So any (IH) plow from that time period would be correct.
What state or area of a state are you in? A lot of plows setting around. But without knowing where you are will not check if what we see would be what you want. Me I am seeing a 3 bottom fast hitch setting out with a for sale sign on it in eastern Indiana. Of no interest to me so I have not stopped to look for model.
