Yesterday's Tractor Co.
Shop Now View Cart
Re: Plow
11-03-2013 18:33:24
Looking at your pictures, I would have to say it is an F620 since it appears to have trip bottoms and 4-bolt wheels. Mine has the optional large tail wheel while yours looks to have the standard small wheel. You can compare it to my JD F620 in the attached pictures. Al
UP Oliver
11-04-2013 17:04:24
 Re: Plow in reply to AJB-830, 11-03-2013 18:33:24
By the way, what model tractor do you have there?
Looks like about a perfect size for what I would like to do.
11-04-2013 21:22:16
 Re: Plow in reply to UP Oliver, 11-04-2013 17:04:24
It's a JD 6230. Has 75 PTO HP and 95 engine HP. In my tough red clay ground it takes the 4-wheel drive. I also have a JD 830 2-cylinder but 4-16s are a little to much for it in my ground, especially packed corn land. If you only have a 53 HP tractor, I would say 4-14s might be a little much to pull in clay ground. My 4-16 F620 plow would stop my Oliver 770 in its tracks if I tried to pull it. The F620 is a nice plow and all wear parts are available from JD. Al
11-03-2013 18:35:51
On closer look at your pictures, it also appears like your plow has the optional large tail wheel. Al
UP Oliver
11-03-2013 18:59:46
 Re: Plow in reply to AJB-830, 11-03-2013 18:35:51
Thanks for the response. What is that large red circular object on the left side of your plow?
11-03-2013 19:49:42
 Re: Plow in reply to UP Oliver, 11-03-2013 18:59:46
Quoting Removed, click Modern View to seethe red circular object is an IH wheel weight.
11-03-2013 20:01:38
 Re: Plow in reply to Handyman, 11-03-2013 19:49:42
Yes it is an IH wheel weight. It was on the plow when I got it and I left it on. You do need it to plow dry red clay especially if your shares have some wear. Al
