TractorLinks.com
Re: Ford Plow 142
maxwell99
10-30-2013 12:24:36
found this plow in the same money range
its a 3x14, but I could take the center plow off and have a modern ford plow, 101 model I think.
my little TO-35 should be able to pull the 2x14 plow and the plow should give me plenty of throat area to turn over debris.
anyone have a plow like this one and does it do a good job???????????
DeltaRed
11-01-2013 16:48:10
 Re: Ford Plow 142 in reply to maxwell99, 10-30-2013 12:24:36
You remove the middle bottom,you will have a screwed-up mess.Remove the 3rd bottom and its framework.Then transfer the landside to the 2nd bottom.do not torch to remove! buy new bolts if you must,but dont destroy anything.Someday you may want to buy a bigger tractor and go to a 3 bottom....
wolfman
10-30-2013 17:09:45
I have a 3 X 14 red Ford 101 also a 3 X 12 101. Excellent plows. Easy to pull, points and shins available. Good plows.
SD Pete
10-30-2013 12:57:35
You will want to remove the back bottom.
maxwell99
10-30-2013 14:30:05
 Re: Ford Plow 142 in reply to SD Pete, 10-30-2013 12:57:35
If I took off the rear plow would I lose the ground guide that is attached to the rear plow?
I assume you would need that part or can it be taken off the third plow and attached to the second plow.
Thanks Fred
