CA 2-14 plow
OldMoIron
I may have posted this earlier, I cant seem to find it. I was trying to plow my old garden spot using my CA that I have posted about in the AC forum. I just cant seem to get the back plow in the ground and if it does go in it works itself out. maybe some insight would help. thanks
Mounted plow right? Did you try putting your left rear tire up on a block the same height that you want your furrow to be? Then set the plow so that everything sits perfectly level on the ground.
Maybe this will help?
You should do what was suggested and run the left rear up on a 7" wood block and adjust the settings.
You may have the plow "Over-Beamed"..that is, set too deep and that causes the rear bottom to run shallow and the front to (probably) run too deep..
Ron.
