Yesterday's Tractor Co.
Shop Now View Cart
Re: JD Grain Drill
10-25-2013 20:09:14
If it is the same style as my single-disk B you have to drill out the rivets joining the housing to the disk to get to the bearing. Instead of re-riveting mine I used pan head screws to put it back together.
10-25-2013 20:25:44
 Re: JD Grain Drill in reply to Brendon-KS, 10-25-2013 20:09:14
I also use small bolts/screws on similar appications.Only use lock nuts and no lock washers.Reg nuts and locks will come lose.Better still is to put a tack weld on the threads.
Tx Jim
10-26-2013 04:00:22
 Re: JD Grain Drill in reply to DeltaRed, 10-25-2013 20:25:44
JDparts shows this for the brg(parts key #14)
The part M60726 is no longer available. Contact your local John Deere dealer for other options.
Then it showed this substitution which is anti-friction brg type disk in 2nd photo.
AM12410 Disk Blade ADD 46.43 USD
M17520 Seal View/Update 1.21 USD
M17849 Bushing View/Update 11.13 USD
This post was edited by Tx Jim at 04:01:46 10/26/13.
