Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere Plow
Jdgal
10-24-2013 19:23:19
I am new to this site. How do I post a picture?
Carlyle Hoffman
10-25-2013 09:03:40
 Re: John Deere Plow in reply to Jdgal, 10-24-2013 19:23:19
No need for further PHOTOS , as it is a OLIVER.
willie in mn
10-25-2013 18:17:48
 Re: John Deere Plow in reply to Carlyle Hoffman, 10-25-2013 09:03:40
No idea what brand the wheels are, but the rest of it, hitch spring release, hitch support rod, & crank for adjusting the furrow wheel are definitely J D # 4, or as my Dad called his, Pony Model.
Willie
rabbit
10-25-2013 07:16:53
I'm no expert, but that looks more like Oliver than JD, to me.
Leroy
10-25-2013 07:51:56
 Re: John Deere Plow in reply to rabbit, 10-25-2013 07:16:53
That wheel rim tells me Oliver as well
Jdgal
10-24-2013 19:24:59
I will take some better pictures tomorrow when it's light out and will write down the beam numbers
B-maniac
10-25-2013 18:00:44
 Re: John Deere Plow in reply to Jdgal, 10-24-2013 19:24:59
The frame/beams of that plow are positively JD 4 and will say 632A on long beam and 583A on short MFg '39-'47. Those wheels are not original to the plow and may very well be Oliver as with the crank.Here is a JD # 4B plow to compare.
Bob Collins
10-25-2013 18:54:57
 Re: John Deere Plow in reply to B-maniac, 10-25-2013 18:00:44
The John Deere #4 and #4A plows have a leveling crank instead of the lever used on the later 4B (and 4C & 4D) This sure looks like a #4 with different wheels. #4 made 1929 -1930. #4A 1930-1935.
B-maniac
10-25-2013 19:18:17
 Re: John Deere Plow in reply to Bob Collins, 10-25-2013 18:54:57
I learn a little more every day on here. Thanks, Bob! RB.
B-maniac
10-25-2013 19:20:32
 Re: John Deere Plow in reply to B-maniac, 10-25-2013 19:18:17
also I misprinted the beam # should be 623A , fingers got ahead of brain.
Bob Collins
10-26-2013 06:14:06
 Re: John Deere Plow in reply to B-maniac, 10-25-2013 19:20:32
And I forgot to mention some of those 4 & 4A plows used beams 583 and 584 before the 623 was used. The suffix "A" is part of the part number but it isn't stamped into the beam.
Tyler-MO
10-26-2013 20:21:09
 Re: John Deere Plow in reply to Bob Collins, 10-26-2013 06:14:06
Bob,
I think it's a No. 4 based on what I can see of the hitch. I've got a very late 4A and it shares many of the same features as the No. 4. The No. 4 hitch was more like a "Y" shape rather than a straight hitch bar and a simple diagonal brace. I've seen some wierd stuff with oliver bottoms on JD plows and what not, but have never seen oliver wheels on a JD plow. It would be interesting to see what the land wheel looks like.
Tyler B in IL
Bob Collins
10-27-2013 11:54:26
 Re: John Deere Plow in reply to Tyler-MO, 10-26-2013 20:21:09
Tyler, What I look for to distinguish a 4 from a 4A is the support for the leveling crank. The 4 has it bolted to the furrow side beam and the 4A has it bolted to the front cross member. Early 4A plows had a one piece support, while later during/after 1934 plows had a two piece adjustable support. In his picture, I can't see where it is attached. There are other differences too, just where I start looking. Bob
Copyright © 1997-2015 Yesterday's Tractor Co.
