TractorLinks.com
Re: AC 2-14
maxwell99
10-24-2013 18:14:40
set up of plow is important.
but, from my experience working years with the old AC snap couple hitch system.
first thing you want to do is crawl under the tractor and be sure the snap couple hitch hook is in excellent working condition.
Insure all the hook cotter pins are in place and in good condition, plenty of tension on the hook to insure it stays hooked to the plow.
over the years I have heard of a number of the under belly snap couple hitchs come unhooked while plowing and the lift arms staying hooked
then the plows can come over on top of you.
just a heads up, be safe!!!!!!!!!!!
install new springs on the lift arm couplers to insure they stay connected, as they can come unhooked.
the snap couple hitch can be quickly hitched to the plow, but it can also come unhitched from the plow quick, if you hit a stump or rock, etc:
Diydave
10-25-2013 04:36:39
 Re: AC 2-14 in reply to maxwell99, 10-24-2013 18:14:40
The key element to make sure of in the snap coupler system is the upper lift clamps. Early WD's used a different type upper coupler that was mounted to the lift arm, by a set screw. You WANT the upper couplers to de-couple, in the event of the bottom coupler coming undone! Make sure you don't use the old style coupler, for the pin hitch plows, in place of the snap couplers.
