Case 3 bottom 3 point plow
Anonymous-0
I am looking for a 3 bottom 3 point plow to pull behind my
Minneapolis Moline U302. I just want to use it to plow gardens,
and to leave attached to the MM at shows. I was thinking a
White, or Oliver plow just to kind of match up with the MM. I
came across a Case 3 bottom, spring trip with a gauge wheel
3 point plow. Anyone have any expirence with one of these?
How hard are wear parts to get? Do they do a good job? I
don't know much about plows due to only using ones my
Grandpa, and Uncle used when I was growing up. Any advice
is appreciated.
I do not know the horsepower of your tractor but for plowing gardens a 3 bottom is way to big, a 2 would be a lot better. Or even a single bottom.
if it has the style of trip of the plow above it is a White plow made for Case very good plows and parts are still available
It"s a spring trip not an auto reset. The auto resets I have seen go for $1,200 to $1,500, which is a little to much for no more than I am going to use the plow for. The more research I have done I think I will keep looking fro a White/Oliver plow.
The U302 is 50 hp. My garden is about 1/2 acre, but I plan on using it for plow days, etc. I understand the 3 bottom might be a little big, but I think it would match up with the tractor better.
may be one of these a "SRT" models also great plows when you said "spring" trip I was guessing on the White plow, the plow in the pic is all Case made
