Been looking for a pull type shredder to clean up some pasture with. Only about 6-7 acres, so don't need much.
Found an old Deere, about 51/2' wide, rock shaft and wheels at the rear, hydraulic lift. Has a double set of short swinging cutter blades attached to a wide center bar, that straddle these dividers coming off the front corners of the deck. Weird hitch that looks like it attaches to mounts similar to a modern 3 point, with a screw leveling device on it. PTO shaft on a pivoting pillow block,
Kind of running through a tunnel in top of deck.
Runs smooth and quiet, and in decent shape, other than pillow block bearing is out, but can't find an ID tag anywhere on it.
Any idea what model? Looked at 127, and this looks earlier to me.
Are they any good? Parts available yet?
