Question on a part number
Texasmark1
Found a part number on my new to me offset disc. It was on a spacer spool. Number is H224-0-7A. Any idea what that belongs to? Is H for IH? Looks like it has a 1 3/4 round shaft and Agri Supply out of NC has the discs for it and the bearings. Other than that, not much to go wrong with it.
Thanks for your time,
Mark
First pic answers your question about disc spacing the other day.
Can't tell much from the photo. Just a 9" round spool to fit a 1 3/4" round shaft.
I added the JD Wheel weights for another 600# of digging in.
Mark
I haven't seen an offset disk similar to yours before. When you stated 8' offset disk the other day I was thinking pull type not 3 pt. 3 pt should be a little easier to pull than a PT.
Yes and the other thing it can do the work without having to be so
long.....room to mount the wheel assys. My hay patch is fenced and
although I have a 15' corridor around it, I still have to be careful in
turning about at the end of the row.
Course you miss the added weight so I made up for that with the
wheel weights.
Mark
