Ford series 951 bushhog
Anonymous-0
I have a Ford series 951 bushhog. It was working just fine, but then
it stopped cutting the fields, even though the PTO is working fine
and the blade is turning. Any suggestions?
Is there a slip clutch in the driveline that might be loose? So that the blades turn when there is no load on it but when you try to cut it just slips? Some models had a shear bolt and if there was enough friction it too would spin the blades but not under a load.
By the way, Bush Hog is a registered trademark.
Your Ford rotary cutter is NOT a Bush Hog®.
