Yesterday's Tractor Co.
Shop Now View Cart
Re: melroe pull type plow
10-02-2013 21:16:21
The set screws don't seem to help much either if you do grind the p shaped piece down just go maybe a 1/4 on each on at a time maybe not even that much it will really make a big difference on how the plows work on hard ground. To get the p shaped piece out I chained each bottom to a big tree and then drove the tractor ahead to trip the bottom its a good idea to use a block of wood to help hold the beam up while you take the piece out just in case the chain broke
10-02-2013 22:09:44
 Re: melroe pull type plow in reply to 4020deereboy, 10-02-2013 21:16:21
I took 1/4 in off the P shaped piece and that solved problem. it will trip on a rock but not from hard ground. Thanks
10-04-2013 10:58:30
 Re: melroe pull type plow in reply to outsidersag, 10-02-2013 22:09:44
Glad it worked for you we were having a hell of a time till I asked on here and somebody told me what I told you . If you do happen to get one set a little to tight there a bolt that acts like a shear bolt to
