TractorLinks.com
Re: Re-plumbing the old sprayer
midtnman
10-02-2013 15:28:34
With a roller pump,you strain between the tank outlet and pump inlet. Keeps grit and whatever
from getting between the close tolerance of the rotor and pump housing wall. With a centrifugal you strain after the pump. No
close tolerances here,but a stopped up strainer on the suction side,you starve the pump, lip seal
heats,warps and you start leaking out the weep
hole on the pump shaft. A positive displacement piston,John Blue you
strain before the pump. Keeps matter from getting under either the inlet valves or discharge valves.
