Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: How much wood splitter is enough?
maxwell99
09-30-2013 20:01:17
I have had a 26 ton splitter for 20+ years. If you have some tough wood to split, you will need at least 26+ tons of pressure.
It's much easier to pack the split wood to the stack rather than having to beat and bang the stuck splitter head out of the wood.
Jim in Ma.
10-01-2013 06:59:25
 Re: How much wood splitter is enough? in reply to maxwell99, 09-30-2013 20:01:17
When you have a piece of wood stuck like that - you have two options. When stuck I pull the ram back and use it to push a splitting wedge in form that end, Or - Use a chain and pull the wood back from the wedge.
gtractorfan
10-01-2013 14:02:05
 Re: How much wood splitter is enough? in reply to Jim in Ma., 10-01-2013 06:59:25
After many years of using my woodsplitter I discovered another way to unjam a stuck piece that usually works. I get another piece of split wood about half as high as the stop plate and put it between the plate and stuck piece. It changes the angle of push and usually will either split the log or raise it up and unjam it.
