Garber seeder, St Paris Ohio PTO hookup
Anonymous-0
Got one that bolts to the draw bar on the tractor. PTO is missing. There is a splined end that looks to be made of aluminum . Trying to find out what the original one that was on there. The rest of its in great shape. Thanks
some had a small class 6 drive shaft and others used a thick wall rubber hose i will ck my parts books tommorrow call link_disallowed ask for larry days and i will try and help you
Cut off an old hydraulic hose, that will fit over the small end, and adapt another to it to make one that fits over the pto shaft, or a shaft adapter.
as others have said, just get a heavy duty straight radiator hose with a couple of radiator hose clamps.
works good,
the tractor pto shaft is 1 3/8" the seeder shaft connector should be the same.
you need to set up the seeder so the pto hose shaft will run straight,
then measure the length of hose you will need.
on my old Ferguson I have to use my angle stabilizer bars as the lift arms will go down after a time, if the motor is not running. if the seeder is not secured then the pto hose will be damaged, if the lift goes down.
I have used my little seeder to spread fertilizer, works great.
