Strange loader
Alright guys I have acquired a loader I have no idea what it is. It was mounted on a jd B. it mounts to the front end and also mounts halfway back on the frame and of course to the rear axle. It raises and lowers powered by the clutch pulley with the belt ran to a pulley mount on the loader frame then you pull a lever when the clutch in engaged to raise and lower it. anybody have any idea what it is.
IDK brands, but early loaders were belt driven- often found on unstyled tractors. Friend of mine has one. Slightly better than a fork.
With it running off the clutch pully it does not sound like a Deere as they ran off a flywheel pully. What model B was it on as that could make a difference? But it sounds like it was made for a Farmall F-20 or simular tractor.
So it would probably be a smaller version than would have mounted on an F-20. more like for a F-12 or 14.
