Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: HP to Pull a 17-Hole Grain Drill
fergienewbee
09-16-2013 03:46:14
Rod;
No I won't be hauling a half ton of seed. More like 30-50 pounds. I can probably plant most of my plots in 3 or 4 passes: cowpeas, oats, wheat, buckwheat, and grain sorghum and millet. If I use a planter, I figure I'll have over $100.00 just in plates. I want a drill, but it's certainly not mandatory.
Larry
Leroy
09-16-2013 07:16:52
 Re: HP to Pull a 17-Hole Grain Drill in reply to fergienewbee, 09-16-2013 03:46:14
With that much only it will not feed out unless you have someone riding on the drill to keep the feeds full. At that size you need a full bushel left in the box after you are done planting and then it would be close to having some of the feeds running empty. And I wonder if that is the correct model as have never heard of that, FB yes is a common model but the letter on the front throws a person off as to what it is.
RodInNS
09-16-2013 06:03:29
I doubt you'll have a problem if that's as much seed as you're carrying. I'd just be worried with a full box if you had to deal with some steep grades.
Rod
