How to measure disc blade
Outside edges. Or if they are really wore down, the distance from the center hole, to the frame X2-the diameter of center hole!
Most folks use a ruler or tape. Measure the blade by putting the center on the ground, and measure the height to the edge. Then measure the blade from edge to edge, then note the axle hole size, usually 1 1/8 or 1 1/4". ASC usually has a size to match it.
