tomstractorsandtoys
We put a 244 cornhead on our 3940 harvester late last fall and it worked great.We went to start today and we are having trouble with the corn piling up between the screen and the auger and filling up the cuterhead housing.Most of the field is in the low 30% moisture but the low spots are very very wet and that seams to be the problem.The operaters manual says it works best with the knives moved out(and we did last fall) but we can not move them again.I do not want to replace knives untill spring because we chop lots of bedding(corn stalks and bean stubbles) wich picks up alot of dirt and stones.If it takes new knives I will but wonder if anyone has other ideas first.The knives are sharp and the screen it is set up good and we are getting a nice cut,maybe a little to fine(we changed the feed roll sprocket to the large side of the fine cut sprocket.We finished corn silage yesterday so the inside of the machine is not rusty,my cross auger is wore but not junk yet.It is working our 4620 harder in second than our corn silage did in forth.We even tried first with little improvement.Our feed man said to aim for upper 30"s on grain moisture so the final produt is 38-42% moisture.The stalks are dead and dry but some of the grain is wet. Thanks for any help.
